Activity Forums AJA Video Systems Canon 550d pro res file size
  • Canon 550d pro res file size
    Posted by Josh Bamber on June 2, 2011 at 9:55 am
    Hi everyone,
    Just a quick one i shot a short film on a canon 550d (T2I) and the original footage was about 25gb. I transcoded it using compressor into Apple pro res 422 lt and the file is now over 250gb, To me this seems huge especially as i only have 1tb of storage. So does this sound about right meaning i will have to get some more hard drive space. or is the file size way to big.
    Cheers
    Josh
    Chad Tingle replied 15 years, 3 months ago 3 Members · 2 Replies
  • Fred Connors jr.
    June 2, 2011 at 12:55 pm
    How long was the film? What compression does the 550d use to get HD Video onto the memory card. Answer these questions and you can do the math as to why it is do big. And yes you need more disk space.
    The Troupe – Modern Media Design & Production
  • Chad Tingle
    June 3, 2011 at 2:36 am
    [Josh Bamber] “I transcoded it using compressor into Apple pro res 422 lt and the file is now over 250gb”
    If you’re using final cut pro 7.0 you can use the log and transfer setting to convert to Apple pro res.
    Chad Tingle
    Producer/Editor
