Activity › Forums › DSLR Video › Canon 50mm FD 1.4 lens on 60D and GH2
Posted by Clyde Villegas on June 29, 2011 at 5:55 amI have an old Canon 50mm 1.4 FD lens. On which camera will I get a shallow depth of field using that lens: on the 60D or on the GH2? Also, I have read somewhere that when using the that lens on the 60D with a mechanical adapter (with no optics), you can only use it for macro shots? Is this true? Does the GH2 share the same problem with this lens?
ut in omnibus glorificetur Deus
Clyde Villegas replied 15 years, 1 month ago 5 Members · 11 Replies -
Noah Kadner
June 29, 2011 at 8:04 amDOF would be identical on either camera. Not sure what you mean about the macro only. If it’s an older mechanical lens it will work equally on either camera as long as you have the right mount adapter.
Noah
Unlock the secrets of 24p, HD and Final Cut Studio with Call Box Training. Featuring the Panasonic GH2 and Canon 7D.
Phil Balsdon
June 29, 2011 at 9:11 amThe FD – EOS adaptor needs an optical element.
This probably why you can only get restricted focus with a mechanical only adaptor.
I seem to remember reading somewhere the results weren’t perfect and images were a little soft.
Cinematographer, Steadicam Operator, Final Cut Pro Post Production.
https://philming.com.au
https://www.steadi-onfilms.com.au/ -
Albert Solan
June 29, 2011 at 3:17 pmHello,
this thread might be of your interest:
https://forums.creativecow.net/thread/280/5521 -
Clyde Villegas
July 1, 2011 at 10:42 pmI’ve read somewhere that since the Canon has a bigger sensor, the DOF will be shallower.
Clyde Villegas
July 1, 2011 at 10:48 pmHow about if I mount the canon 50mm fd lens on the GH2, can I get by with the mechanical only adapter (without the optical element) and still be able to focus to infinity?
Clyde Villegas
July 1, 2011 at 10:50 pmThanks for the link, Albert. Do you know of a similar thread for the GH2 with FD lens?
Clyde Villegas
July 2, 2011 at 12:43 amAccording to Wikipedia as it talks about the GH2, “The format, with its crop factor of two, is capable of shallow-focus effects (desirable for the ‘filmic’ look where backgrounds are deliberately made out-of-focus with good bokeh, but compared to a ‘full-format’ camera such as the EOS5D it requires lenses with twice the aperture (half the f-number) for the same depth of focus.”
The link is here: https://en.wikipedia.org/wiki/Panasonic_Lumix_DMC-GH2
So if this is the case, then the 60D with it’s larger sensor will have a shallower depth of field than the GH2 given the same lens. However, it looks like the FD lens will lose quality with when used with an adapter (with optical element inside). What do you guys think?
Phil Balsdon
July 2, 2011 at 7:15 amCanon FD lenses
Avoid the Canon FD lenses. You need an adaptor with glass in it to make it work with the EOS cameras and they simply do not work well. Soft am afraid! A real shame as there are lots of affordable FD lenses out there…
From this page
https://philipbloom.net/2010/08/20/which-lenses-to-buy/
Clyde Villegas
July 2, 2011 at 7:44 amHow about the performance of the FD lenses on the GH2, instead of the EOS cameras. Are they sharp on the GH2?
Ryan Orr
August 5, 2011 at 8:31 pmYou must understand. With a mechanical only adapter, you are sacrificing infinite focus. You may be getting ‘softness’ and ‘lack of infinite focus’ confused and using the two terms for what you think is the same thing.
To get that infinite focus back, you’ll need an adapter WITH the corrective glass built into it.
FD glass is great, and you can find some awesome deals out there. However, they won’t be tack sharp as the newer lenses, and you will always have to work with the limitations of the adapters. It won’t matter which camera you are using. Both the 60d and GH2 are supreme cameras with nice video options, with nearly identical features and settings.
Either camera will not get you better performances from the lens…it’s the lens that will get you the better performance.
