Activity › Forums › Canon Cameras › Canon 30p Capture
  • Canon 30p Capture
    Posted by Bigbee36 on November 27, 2007 at 2:13 am
    I am having trouble digitizing footage into Final Cut Pro. It was shoot with an Canon XL2 and recorded at 30p and in 16×9. When I try to capture I get about 2 minutes into the capture and my deck pauses. On capture window i get a message that says looking for timecode breaks. I know that their a not breaks in the tape. I capture things all the time, but this is my first time capturing footage that was shoot in 30p. Do I have to set up my preferences in some special way to capture footage. Or is it my deck that is causing the problem. Working on a special projects and it would be a shame not to be able to get this footage in.
    Truly Lost,
    Brian Briggs
    Mac OS 10.4.10
    2×3 GHZ Dual-Core Intel Xeon
    Final Cut 6.01
    2GB Ram
    G-Raid 600GB
    JVC HR-DVS1U
    Canon XL2
    Donald Berube replied 18 years, 9 months ago 3 Members · 2 Replies
  • Don Greening
    November 28, 2007 at 6:12 am
    To capture widescreen 30P just use the same FCP preset that you would normally use to capture 60i from your XL2, which is DV NTSC Anamorphic if you live in NTSC land or DV PAL Anamorphic if you live in PAL land.
    If you’re still having TC break issues and you know for sure there are no breaks on the tape, trash FCP’s preference files and give it another go.
    – Don
  • Donald Berube
    December 6, 2007 at 4:46 am
    FYI, whenever I have had excessive timecode break problems when trying to capture Canon footage I have always had success by alternatively digitizing my footage into a FireStore and then importing the clips from the FireStore into FCP.
    It’s a solution to consider when all else fails.
    – Don
    https://noisybrain.com
    https://www.bosfcpug.org
