Activity Forums Adobe Premiere Pro Canon 24F Frame Rate Issue – please help
  • Canon 24F Frame Rate Issue – please help
    Posted by Tomadonna on September 23, 2007 at 2:54 am
    For some strange reason, when I capture footage shot in the Canon XH A1 in 24F into Premiere CS3, it recognizes it as having 44.96fps.
    The same thing happens if I import a file captured via HDLink, HDV-Split or Vegas – premiere thinks the footage has a 44.96 frame rate. I tried importing the m2t files into AE and got the same problem.
    If I import the m2t files captured via Cineform (or other third-party capturing softwares) into Vegas, it displays and plays the files in the correct 23.976 fps.
    Has anyone experienced this or have any suggestions?
    Brian Gutierrez replied 17 years, 11 months ago 3 Members · 4 Replies
  • Mathew Joki
    October 24, 2007 at 6:07 pm
    I’m having the same problem capturing/importing 24F footage from my XL-H1, with the Canon PPro capture/timeline presets. The only thing that I’ve been able to figure out to fix it is going into the “Interpret Footage” settings in PPRO (CS3) and setting the framerate to assume 23.976 fps for the footage. I can’t for the life of my come up with a reason why the footage would be interpretted as such an arbitrary framerate like 44.955 though!
    I’m interested to find out if anyone know what’s causing this glitch though. Or if any knows if it will cause audio sync problems? So far, all I’ve tested it out on is MOS footage that I shot, so I can’t tell if that will be an issue or not…
  • Mathew Joki
    January 31, 2008 at 10:06 pm
    https://www.dvxuser.com/V6/archive/index.php/t-116746.html
    This is the only other resource I could find on the subject. I guess this is being chalked up to incomparability with CS3. I guess just stick with the CineForm Device Capture settings….
    I now have to re-capture 19 HDV tapes because of this BS….
  • Mathew Joki
    January 31, 2008 at 10:08 pm
  • Brian Gutierrez
    October 4, 2008 at 8:00 am
    I have the same problem.
    I was able to get the canon HDV preset adobe to install and work in CS2, but can’t get CS3 to do the same.
    I really paid a lot to upgrade to CS3 and i really don’t get why i did.
    44.96 head aches.
    When i deleted the Adobe editing presets xml from the CS3 plugin/editing_modes directory i can get the supposed functionality, but in practice it the files are still interpreted as 44.96.
    I’m curious as to what i’ll end up with in CS2. I’ve made a of projects in CS2, but was sold on CS3 because of a convoluted track time stretching feature.
    Does anyone have any suggestions how to get this Canon XH-A1 to capture in CS3 with HDV 24f
