Activity › Forums › VEGAS Pro › Cannot use AVI files in Sony Vegas.
  • Cannot use AVI files in Sony Vegas.
    Posted by Genero Lundgren on June 6, 2011 at 1:24 pm
    Hello i got a new computer and I’m running Windows 7 64bit, i have the same codec pack as my last computer but i can’t use any .AVI files in vegas no more? Please help i have tried several codec packs but nothing seems to work.
    If you want me to say my computer specifications ill do that.
    Thanks in advance!
    -GeneroEdits
    Gilles Gagnon replied 15 years, 3 months ago 4 Members · 6 Replies
  • John Rofrano
    June 6, 2011 at 3:18 pm
    [Genero Lundgren] “Hello i got a new computer and I’m running Windows 7 64bit, i have the same codec pack as my last computer but i can’t use any .AVI files in vegas no more?”
    If you are using 64-bit Vegas you will need the 64-bit versions of your codecs so the old 32-bit versions will not work.
    [Genero Lundgren] ” Please help i have tried several codec packs but nothing seems to work.”
    This is the worst thing you can possible do. Never install a codec pack. It can (and does) overlay the good codecs that Vegas supplies with inferior ones that will cause Vegas not to work.
    You should use a free utility like GSpot to determine which codec your AVI uses and only install that one codec from the manufacturer. Once again, if you’re using 64-bit Vegas, GSpot may tell you that the codec is installed but it’s only looking at 32-bit codecs so you still may need to install the 64-bit version of the codec if it even exists.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Gilles Gagnon
    June 6, 2011 at 8:35 pm
    Thanks for the tip John,
    I assume that if one has installed a CODEC pack and wants the Sony originals, a simple Vegas re-install will do the trick?
    Gilles
    Gilles
  • Steve Rhoden
    June 6, 2011 at 11:03 pm
    No Gilles…You need to uninstall those codecs and if push comes to
    shove and you cant uninstall, a system restore to before they
    were installed could also work.
    Steve Rhoden
    (Cow Leader)
    Film Maker
    Filmex Creative Media.
    1-876-832-4956
  • Gilles Gagnon
    June 6, 2011 at 11:44 pm
    Thanks Steve,
    Doing a sys restore is out of the question as it’s been too long since the codecs install.
    what I don’t understand then is that John mentions “overlay the good codecs that Vegas supplies…” … why wouldn’t a reinstall of Vegas bring them back?
    G
    Gilles
  • John Rofrano
    June 7, 2011 at 3:47 am
    [Gilles Gagnon] “what I don’t understand then is that John mentions “overlay the good codecs that Vegas supplies…” … why wouldn’t a reinstall of Vegas bring them back?”
    Codec packs are quite nasty. The seldom totally uninstall themselves cleanly and re-installing Vegas doesn’t always undo the damage. Some of them act as surrogates for several codecs and redirect output and it gets quite messy to untangle. Reformatting your PC is often the only solution to get rid of the problem which is why I say never install them in the first place.
    ~jr
  • Gilles Gagnon
    June 7, 2011 at 10:38 am
    Yikes!
    Thanks for the info John.
    G
    Gilles
