Activity Forums Apple Final Cut Pro Legacy Cannot transfer sequence between two projects
  • Cannot transfer sequence between two projects
    Posted by Chris Farrington on October 22, 2008 at 3:25 pm
    I am having a lot of bugs here and I will make two posts because there seem to be two big problems.
    Biggest one – I cannot transfer a sequence between two projects. This is a major problem because it means I can’t bring in anything from an autosaved version of my project.
    I have my current project. To make things easier, I create a new project. I try and drag the sequence from my current project into the new empty one. As soon as I drop it in the new one, the spinning beach ball appears. Nothing happens until I quit out.
    This used to happen sometimes but the autosave would snap it out of the trance. Now, however, the ball just keeps on spinning until I quit.
    Chris Farrington replied 17 years, 10 months ago 2 Members · 2 Replies
  • Walter Biscardi
    October 22, 2008 at 3:39 pm
    How long is your sequence? If it’s a long one, it can take FCP up to 10 minutes to fully transfer all the information to your new project. The spinning beachball is normal when you drag a sequence from one project to another. How long that stays on screen depends on how long your Sequence is and how much media it has to refer to.
    Also, if your media is spread out over multiple drives, it will take even longer.
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    Read my Blog!
    STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
  • Chris Farrington
    October 22, 2008 at 3:48 pm
    I don’t think that’s it for the following reason:
    On a whim, I just now tried something else.
    Instead of dragging the sequence from one project to another, I copied it from the old sequence and pasted it into the new one.
    Works fine and immediately.
