Activity Forums Apple Final Cut Pro Legacy Cannot submit batch
  • Cannot submit batch
    Posted by Hal Beery on April 21, 2005 at 7:05 am
    error message: “unable to connect to background project. cannot submit batch”.
    what happened???? I highlighted the sequence then file, export, compressor, etc.
    What’s going on? How to fix?????
    TNX!
    Hal Beery replied 21 years, 5 months ago 4 Members · 5 Replies
  • Nick Toth
    April 21, 2005 at 2:37 pm
    Go to Compressor discussions on Apple support website. There are a number of different things that might cause and/or fix this.
    First try deleting Compressor and re-installing including the 1.2.1 update.
    There is some kind of network issue involved.
  • David Bogie
    April 21, 2005 at 3:11 pm
    It’s a complicated issue, far too many possible explanations and cures to list here.
    Hit apple.com
    and search for your terms. You are going to disappointed that there isn’t a magic bullet but you should eventually find an answer among the dozens of threads.
    https://discussions.info.apple.com/webx?14@178.RxF3aPn5AlN.496586@compressor
    bogiesan
  • Ed Dooley
    April 21, 2005 at 3:24 pm
    As Nick and Bogie said, it can be any number of things. Here is the fix that worked for me:
    go to finder, go, go to folder
    type /etc/
    view as icons
    locate “hostconfig” and COMMAND then click on file and drag to desktop.
  • David Bogie
    April 21, 2005 at 3:28 pm
    First thing to try:
    Disconnect all network. This means Firewire, USB and ethernet.
    Compressor “looks for network engines” according to some wonks. All buses are considered network ports.
    bogiesan
  • Hal Beery
    April 21, 2005 at 4:06 pm
    Thanks, All!
    I’ll give it a go.
    HalB
