Activity Forums Adobe Illustrator Cannot stetch shapes?
  • Cannot stetch shapes?
    Posted by Tom Scott on April 9, 2009 at 2:28 am
    Hey im fairly new to illustrator, it has been working fine until recently.
    With the normal cursor i cannot drag and stretch objects instead i have to use the specific tool, to scale objects.
    This is really frustrating so even if it sounds like a stupid question you help would really be appreciated, thanks
    im using adobe illustrator CS3
    Thie Thomsen replied 17 years, 5 months ago 2 Members · 3 Replies
  • Thie Thomsen
    April 10, 2009 at 2:21 pm
    What pointer tool are you using? The white or the black one.
    You can’t scale with the white one, as this one is specifically for moving/selecting anchorpoints/lines. The black one is for moving/stretching entire objects.
    I can see your spot colours…
  • Tom Scott
    April 10, 2009 at 11:06 pm
    yeah im using the correct cursor, but it seems as though somehow the attributes have copied to the other cursor
    thanks for the response
  • Thie Thomsen
    April 11, 2009 at 9:51 am
    in that case it sounds like you’ve accidentally hid your bounding boxes.
    ctrl+shift+b toggles them back on (command+shift+b on a Mac).
