Activity Forums Adobe After Effects Cannot Standard Preview – Occasionally via different projects
  • Cannot Standard Preview – Occasionally via different projects
    Posted by Kazumi Hatori on July 16, 2012 at 5:12 pm
    I’ve been used to use standard preview (Spacebar / play button) all the time,
    via I find sometimes while I press spacebar(or play button), the timeline just go forward 1 frame only.
    It’s ok with the RAM preview.
    And the point is, on some projects, I got the normal SPACEBAR,
    via some projects, after working for a while, don’t.
    I wonder if I disable that in any way that I don’t know?
    Kazumi Hatori replied 14 years, 2 months ago 62,764 Members · 3 Replies
  • Kazumi Hatori
    July 16, 2012 at 6:19 pm
    Ok, I learnt the difference.
    But sometimes I really need a quick way to just know what’s stuffs going on in 4-5 frames, frequently.
    anyone?
  • Kazumi Hatori
    July 16, 2012 at 7:26 pm
    Thanks, so I just tried,
    I B and N, set area, press 0, the green bar shows it render the area,
    and the area wouldn’t play, why is that?
  • Kazumi Hatori
    July 16, 2012 at 8:36 pm
    Yup,
    on Num Pad,
    and it really does render (see the bar turn green in the area)
    I wonder if that’s because of anything about image cache??
