Activity Forums Adobe Premiere Pro Cannot select clips on Audio (1) track
  • Cannot select clips on Audio (1) track
    Posted by Jeff Friah on August 14, 2015 at 10:07 pm
    Hi – audio 1 track is not muted or locked, yet I’m unable to select anything or make trims. All other audio tracks respond fine.
    Thoughts?
    Also – perhaps related, I’ve got single waveform audio pieces as well as some that look like two waveforms one over the other — should a track not be mono or stereo? This interviewee sounds ‘twice as loud’ as others and I noted she has ‘two channels of audio’. Without being able to select and move to another track to try to separate, I’m kinda stuck.
    “Sounds good!….I think?”
    Jeff Friah replied 11 years ago 2 Members · 3 Replies
  • Ann Bens
    August 16, 2015 at 12:23 pm
    If the track is in ‘Track’ mode you will not be able to select individual clips. Track needs to be in ‘clip’mode.
    Adobe Certified Expert Premiere Pro CS6/CC
    Adobe Community Professional
  • Jeff Friah
    August 19, 2015 at 3:12 pm
    I’m sorry, I’ve done a search and cannot find how I would check the mode or to switch said mode.
  • Jeff Friah
    August 19, 2015 at 5:22 pm
    I’ve had to workaround by copying and pasting to a new track.
