Activity Forums Adobe After Effects Cannot see Raytrace Output with new Quadro 4000 (Mac)
  • Cannot see Raytrace Output with new Quadro 4000 (Mac)
    Posted by Declan Zimmermann on April 17, 2013 at 1:16 am
    Hello,
    I searched for a thread but haven’t found one so here’s a post.
    New computer (a week old) and I got the Nvidia Quadro 4000 GPU.
    All and latest drivers installed.
    AE has been updated (11.0.2.11)
    If I enable the Ray-Trace 3D renderer and set it to use the GPU (which AE is seeing just fine, and meets all the requirements per online research) my 3D later disappears.
    It only works in Draft mode, otherwise i just see a wireframe.
    In RAM previews the layer does not show up at all.
    Preview settings (copied from AE):
    Fast Draft: Available
    Texture Memory: 200.00 MB
    Ray-tracing: GPU
    OpenGL
    Vendor: NVIDIA Corporation
    Device: NVIDIA Quadro 4000 OpenGL Engine
    Version: 2.1 NVIDIA-7.32.12
    Total Memory: 1.00 GB
    Shader Model: –
    CUDA
    Driver Version: 5.0
    Devices: 1 (Quadro 4000)
    Current Usable Memory: 1.82 GB (at application launch)
    Maximum Usable Memory: 2.00 GB
    Anyone else encountered this issue? And better, can anyone suggest a solution?
    Thanks in advance.
    Declan Zimmermann replied 13 years, 4 months ago 2 Members · 3 Replies
  • Declan Zimmermann
    April 17, 2013 at 2:21 am
    Correction: it only works in “Fast Draft” mode and there is a typo above – it should read the layer disappears, not “later” (sorry, it’s been a long day here…)
  • Todd Kopriva
    April 17, 2013 at 3:14 am
    See this:
    https://forums.adobe.com/message/5222748
    After Effects team blog
  • Declan Zimmermann
    April 17, 2013 at 3:40 am
    Thanks for the helpful link, Todd!
    While I did not find the SDK files referred to in that thread, I did resolve the issue by:
    1. Trashing the files in Developer/NVIDIA (after making a backup copy)
    2. Reinstalling the latest drivers from https://www.nvidia.com/object/mac-driver-archive.html
    All is working as it should now; I just posted the steps I took in case it is helpful to anyone else.
    Appreciate the prompt response too!
