Activity › Forums › Avid Media Composer › Cannot see effect in edit mode
  • Cannot see effect in edit mode
    Posted by Steve Rogalinski on July 25, 2016 at 5:11 am
    Suddenly I am no longer able to see an effect in edit mode while sitting parked on the timeline. It only shows up if it is a real-time effect and I play it, or if I go into effects mode, or if I render it.
    But parked on the timeline, I cannot see it. If I put a 3DWarp on a clip, the screen is blank unless I play the timeline.
    I’ve trashed MCState and my settings and still no luck. I am also in GREEN mode, not YELLOW, under the timeline.
    Any ideas would be very appreciated!
    Steve Rogalinski
    Michael Phillips replied 10 years, 2 months ago 3 Members · 2 Replies
  • John Pale
    July 25, 2016 at 11:52 pm
    Make sure Render On The Fly is enabled. In the current version of Avid its in the Composer menu.
  • Michael Phillips
    July 26, 2016 at 12:15 pm
    And there’s another one in trim settings specific to trim. And it used to be that when in trim mode the “special” (pre-8.5) would change for trim specific.
    I think an NLE in 2016 should no longer have these performance savings settings. In the case of MC, you can still mute/unmute, or solo a V track to enable referencing of tracks to each other for creative work. No need for the other ones and suggest they all be ON and settings removed.
    Michael
