Activity › Forums › Apple Final Cut Pro Legacy › Cannot Render File
  • Cannot Render File
    Posted by Abram Corbett on March 10, 2007 at 1:29 am
    If anyone can help on this I will be grateful. I am stuck severely, I was using LiveType to make lower third graphics. One day the livetype graphics are working fine, then a few days later I pick up where I left off on the project and add a few more Livetype files and they won’t preview. So I go to render all the timeline and this is the error i get.
    “Codec not found. You may be using a compression type without the corresponding hardware card.”
    I have never seen this error before, and let me tell you I tried everything I could think of to fix it and still same error message. I tranferred the project to another computer, I converted the Livetype file to .mov, I changed FCP audio/video settings, compression settings, and other small stuff. All my work is now locked up until I can render the timeline and export the file. Has anyone delt with this?
    “What we do in this life echoes in eternity”
    Abram Corbett replied 19 years, 6 months ago 1 Member · 0 Replies
  • 0 Replies
