cannot render…
Posted by Ronald Jones on November 11, 2009 at 3:03 pmWhat might be the reason that my custom options for rendering are greyed out on certain formats??? help
Jeremy Rasnic replied 16 years, 10 months ago 3 Members · 2 Replies -
D. Eric franks
November 11, 2009 at 5:26 pmCan you give us a particular example?
Different codecs support different sorts of things. Some have more options than other. Plus, the engineers at Sony Media Software choose what to reveal and what to hide with some codecs. And even then, some codecs support some things and not other, such as alpha channel (RGBA, RGB+, 32-bit color) transparency.
Jeremy Rasnic
November 12, 2009 at 4:08 amOne reason is that you have to check something to open up those options. For instance, if you have Constant Bitrate selected, you cannot change options under variable bitrate. Ensure you have the option selected that is attached to the greyed out options.
j razz
https://www.jrazzcreations.com
