Activity › Forums › Apple Final Cut Pro Legacy › Cannot Render
  • Posted by Mdchought on March 7, 2006 at 4:27 pm
    FCP will not render any of the clips in my timeline that need rendering. I’ve exhausted all the options in the Render Selection, Render All, and Render Only menus with no avail. Don’t know if this makes a difference, but the Render Manager menu in the Tools pulldown shows no folder. But i think there’s no folder because nothing has been rendered. Is there a setting that i might be missing in one of the A/V setting or preferences folders. The only other issue that i’m not 100% on which might be throwing off the system is how i prepared FCP before capturing 24p footage. In the Easy Setup if forgot to change the setup from DV NTSC to the 24p setting. What’s the deal here????
    Debe replied 20 years, 6 months ago 4 Members · 4 Replies
  • Bouncing Account needs new email address
    March 7, 2006 at 5:27 pm
    The first thing to always try is to Quit FCP, Restart the Mac, Open your FCP project and try again.
    Next:
    THE FOLLOWING COMES FROM THE KEN STONE WEBSITE:
    “Over 5,000 years ago Confucius wrote: ‘If you are toiling away, you have changed nothing and FCP heads South on you, [starts behaving in strange ways] then it is time to trash your FCP Preferences.’ ”
    A great way to do this is to use “FCP Rescue” a free Apple Script that will Trash the Preferences for you (and restore nearly all of your user settings afterward).
    There are versions for FCP (Pro) & FCE (Express) and a new one for FCP 5.
    Download these free Apple Scripts at
    https://fcprescue.andersholck.com/
    or
    https://pistolerapost2.com/fcprescue/
    This is one FCP tip that has helped in solving hundreds of “odd” problems.
  • Steve Eisen
    March 7, 2006 at 6:29 pm
    Make sure that every line is CHECKED in your render settings under Render All, etc. That is often overlooked.
    Steve Eisen
    Eisen Video Productions
    Director-At-Large
    Chicago Final Cut Pro Users Group
  • Mdchought
    March 7, 2006 at 7:03 pm
    That FCP Rescue seems to have worked like a charm. What purpose do the preferences serve, and is there any risk in deleting them. Probably should have posted this before I trashed them. Oh well live and learn, but seems to have fixed the render problem.
  • Debe
    March 7, 2006 at 9:06 pm
    Anything you changed in the User & System Preferences, or if you customized any layouts or the keyboard will be gone.
    It basically resets the system to “factory default”, as it was right after you installed it.
    If you saved your layouts and keyboard, you just have to reload them. User and System prefs you changed will have to be re-set. Once you get them where you want them, you can launch FCP Rescue and use that to backup the new prefs so the next time you use FCP Rescue, you can restore those prefs after a trashing.
    debe
