Activity › Forums › Apple Final Cut Pro Legacy › cannot recapture media from Canon T2i
Jerry Hofmann replied 15 years, 7 months ago 4 Members · 14 Replies
Tory Stewart
December 13, 2010 at 11:20 pmHi Jeremy,
Thanks for running a test. The volumes only refuse to mount when I open the FCP Project on a different computer. In the office I used Log & Transfer to transcode from the H.264 files and took a copy of the project file and the H.264 files home with me. When I opened the project at home, mounted the volumes in the Log & Transfer window, highlighted all the offline clips in the Browser and selected Batch Capture from the drop-down menu, I got the error window I posted above.
I ran a test in the office and Batch Capture works without any issue, so I guess it isn’t something having to do with the T2i hack unless it is somehow triggered by opening the project on a different computer. Really at a loss at this point, it doesn’t really affect my workflow at this point but I worry about delivering a larger project with the H.264 files.
Tory
Jeremy Garchow
December 13, 2010 at 11:21 pm[Tory Stewart] “so I guess it isn’t something having to do with the T2i hack unless it is somehow triggered by opening the project on a different computer.”
Hmm, that’s something I will have to test tomorrow. Good thinking, though.
Jeremy
Maurice Brake
February 3, 2011 at 9:21 amI am having a capture problem from a tape, I print to Video through Final Cut 7 using a HVR M35e Deck on playing back the tape the time code is not registering so unable to make IN and OUT points have tried to capture NOW only captures 2seconds and then Searching for Media.
Rewinding the tape Time Code is showing.
Has anyone had this problem before and how can I capture the media back into Final Cut.Maurice
Jerry Hofmann
February 3, 2011 at 12:41 pmThis should be the start of it’s own thread… but I’ll answer…
You need to dub the tape… create a new timecode track that way. If you dub via FW deck to camera or whatever, you’ll lose no quality.
Jerry
Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
Current DVD:
https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX – Cinema Displays I have a 22″ that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
