Activity › Forums › Adobe Premiere Pro › cannot re-install PPro
  • cannot re-install PPro
    Posted by Tom Kays on May 20, 2010 at 6:39 am
    I am having some issues in PPro so thought the best solution is to re-install the PPro component of CS2. The installer program continues to ask to insert the DVD disc 1 into the drive even though it is already in the drive. It repeats this message over and over without beginning the installation. I’ve removed the disc and reinserted it into another drive but to no avail. How can I get around this to re-install the program?
    Tom Kays replied 16 years, 4 months ago 2 Members · 2 Replies
  • Brian Louis
    May 20, 2010 at 10:24 am
    After the original time you installed the suite did you do anything like add harddrives that would change the ID letter of the optical drive?
  • Tom Kays
    May 20, 2010 at 3:16 pm
    There has been no changes in hdd but have added another optical drive which I’ve used both of them to read disc 1. The only changes are that I use a number of external hdd to store my video projects which are not always connected to this computer. I’m thinking I might have to uninstall the entire suite of CS2 to install PPro but that may may not work either.
