Edward Troxel
November 19, 2005 at 9:26 pm -
Neil Slade
November 20, 2005 at 6:04 pmWell, I understand, however, this is a tape being formatted for regular TV broadcast, which is low resolution to begin with, not HDTV. Mpg files look perfectly good on interlaced TV, as which DVDs are.
I attempted to make a BEST render back to AVI, and was completely unsuccessful after many tries- always a glitch/error before finishing. Good grief, you would think there would be something in the Vegas manual about restrictions, but there are not.
A regular GOOD quality AVI can be re-rendered from the mpg file, and that will print to tape.
Nothing in the Vegas manual says anything, however, that alludes that ONLY avi files can be written to tape- obviously not true, because I did exactly this with my first 18 minute section of film.
Neil Slade
http://www.NeilSlade.com
The AMAZING Brain Adventure -
Neil Slade
November 21, 2005 at 4:08 amPROBLEM
1) I printed to tape an MPG project of 18 minutes to tape. No problemo
2) Tried to repeat process with identical type of project of 55 minutes. Error every time at some point.
Different points, but after a certain length of time- project errors out.3) Defragmented, moved temp folders, nothing worked. After a certain amount of time, unpredictably so- the thing crashes.
4) FRONTAL LOBES POP!!!
5) I opened a generally really really excellent program- DISKKEEPER PRO for defragmenting the hard drives.
IT WAS RUNNING all by itself, and on the drive my temp Vegas and rendered files were going on. It ground the rendering frame rate to less than snails pace. I stopped the program– didn’t even know WHY it was running all by itself, I certainly didn’t turn it on– and as soon as I stopped it- voila, the rendering frame rate sped up to normal, and the project completed.Apparently, as I soon found, I had accidentally turned on AUTO DE-FRAGMENT on the very drive I was using for files in Vegas. No wonder the project wouldn’t finish. Apparently, every hour or so, the Diskeeper program began running, and invariably sabatoged my 55 minute project.
I would recommend Diskeeper to everyone and anyone, it is really a great program, much better for defragmenting than regular Windows XP defragmenter– but for gosh sakes–DON”T LET IT AUTO DEFRAG!!
Big Duh.Please see my movie at http://www.MirrorMovie.com for PREVIEWS.
It will be broadcast throughout Colorado on KBDI Channel 12 PBS in January, prime time on one Saturday night. All done with Vegas and a Panasonic DVX100 24fps progressive. Man it turned out GREAT!Thanks
Neil Slade
