Activity › Forums › Apple Final Cut Pro Legacy › Cannot output through Firewire
Posted by Mark Mcdonald on May 22, 2009 at 5:22 pmOdd Glitch…
I have a FCP (6) running on an old G4 that has run flawlessly for the simple cut long form,(2-3 hr meetings) editing.
As of yesterday, I cannot output to any firewire deck DVCPro, or DVCam. I can Capture just fine, but cannot record out onto these decks.
I’ve check permissions, Settings on both FCP(Apple DV Firewire- Enabled) & Decks(ilink enabled), Changed FW cables, Rebooted. Nothing.
any help would be appreciated.
Thanks in advance.
Mark
Shane Ross replied 16 years ago 3 Members · 3 Replies -
Shane Ross
May 22, 2009 at 6:07 pmTry these steps:
Shane’s Stock Answer #8: External Monitor Viewing (edited)
If for some reason you can’t view your timeline on your external monitor, there are a few things to try:
1) Make sure that the camera/deck is connected and powered on BEFORE you open FCP.
2) In the Final Cut Pro menu select AUDIO/VIDEO Preferences and make sure your signal is being sent out thru Firewire DV.
3) Go to the menu and select VIEW>EXTERNAL>ALL FRAMES.
4) Click in the % box above the image and select FIT TO WINDOW.
5) Go to VIEW->refresh A/V devices
6) Make sure the Log & Capture window is closed
Shane
Read my blog, Little Frog in High Def -
Ilene Cutler
September 16, 2010 at 7:03 pmShane- I am having a problem connecting thru firewire using my Sony HD-1000 having
shot in HD I have set all capture presets to HD and the camera is in HD. I have tried 2 computers with
FCP and used 2 different firewires and it is still not being seen. Help!Ilene
Shane Ross
September 16, 2010 at 11:51 pmYOu can’t output a signal through an HDV camera like you can DV. The format is too complex.
#25 HDV external Monitor Viewing
Shane’s Stock Answer #25 – HDV external Monitor Viewing
To view HDV on an external monitor in high definition you are going to need to purchase a capture card, like the ones Decklink (https://www.decklink.com) or AJA (https://www.aja.com) offer. They will both play out HDV in real time. The catch is that you cannot view this on a regular TV or NTSC monitor. Since this is HD, an HD monitor will be needed. HOWEVER, both cards are capable of down converting the signal so that it can be displayed on an SD monitor. This won’t be color accurate
The real reason why you can’t monitor HDV through a Firewire camera is because Firewire HDV cameras don’t decode incoming HDV streams and route them to their outputs like DV cameras do.
Good options for you are the Matrox MXO2 mini…$450…coupled with an HDTV. Or a Matrox MXO (DVI connection) coupled with an Apple 23″ display gets you good quality.
And there are the Decklink Intensity and Intensity PRO cards as well, and the AJA I/O Express…
You can, however, view HDV out via firewire as DV…lowering the resolution to that of DV, but still viewable. This is not full quality nor should it be used to judge the quality of your footage or used to color correct to. This is just a way to view the footage on a large monitor.
Here are some examples of some of the possibilities:
– DV or HDV sequence output to an SDI signal on a third-party interface
– An uncompressed NTSC or PAL sequence output to a DV FireWire output
– An HDV sequence output to a DV FireWire outputSequence and output formats must have compatible frame rates. For example,
sequences with a frame rate of 60, 30, or 24 fps can be output to a 30 fps device,
but not to a 25 or 50 fps device.Shane
