Activity Forums DaVinci Resolve Cannot Output from Deliver Page
  • Cannot Output from Deliver Page
    Posted by Peter Robertson on November 17, 2021 at 4:08 pm
    I have some clips which had to be recovered from corrupted files.
    The clips play correctly and I can edit and colour correct, however in Deliver page the process reports an errer at the end of the clip and exits.
    Any ideas?
    Resolve 17.4.1
    Peter Robertson replied 4 years, 9 months ago 3 Members · 5 Replies
  • Tom Watson
    November 17, 2021 at 4:31 pm
    What did you recover?
    If you recovered a Timeline, that Timeline may still be corrupted.
    This happens. In the same project, create an new empty Timeline. Go to the Timeline you recovered. Lasso all of the clips and copy them to the clipboard. Then go to the newly created Timeline and paste them. I have done this many time to successfully recover files.
  • Peter Robertson
    November 17, 2021 at 4:38 pm
    Thanks Tom for your fast response with help.
    The clips were corrupted from the camera and would not play with VLC etc. I used an online service (at a cost) to recover the data. In the deliver page they play up to the end and then Resolve reports the error.
  • Tom Watson
    November 17, 2021 at 5:03 pm
    That is different. Not a Resolve problem. I have found VLC doesn’t offer much help in determining the usefulness of a video file. Media Player Classic, the last version they made, is much better. But, none of these can fix your problem.
    I would try looking at one of the recovered clips with MediaInfo and/or ffprobe to see if you can find out what is wrong with the file. They can often be repaired with ffmpeg, but that is not something I can talk you through.
    There are others on this forum much more qualified to help. Hopefully, you will get more help as others see your question.
  • Eric Santiago
    November 18, 2021 at 2:57 pm
    Have you tried different formats for delivery?
    Even DPX?
    Not sure how long that timeline is but maybe piece meal it.
  • Peter Robertson
    November 18, 2021 at 3:04 pm
    Hi Eric
    I think I have a workaround.
    I joined these suspect clips together using Quicktime and found that I could cut them again and that these snipits no longer caused a problem for Resolve.
    Thanks to all contributers
