Activity Forums Adobe After Effects cannot open QuickTime.mov
  • cannot open QuickTime.mov
    Posted by Isabella La rocca on December 15, 2009 at 3:15 am
    i’m trying to open a movie I rendered from After Effects 5.5 in Feb. of 2005 using Animation or None compression. When I try to import it to AE CS4 I get the following message:
    AfterEffects error: file “filename.mov” cannot be imported – this ‘MooV’ file is damaged or unsupported.
    When I try to open it in QuickTime 7.0 I get the following message:
    The document “filename.mov” could not be opened. The movie is not in a format that QuickTime Player understands. You may need to install additional software to open this type of file.
    PLEASE HELP!!!
    Thank you,
    Isabella
    Ruben Contreras replied 11 years, 5 months ago 5 Members · 4 Replies
  • Joe Stenhouse
    December 15, 2009 at 5:29 am
    Not to sounds redundant but the errors that you are recieveing are in fact correct and tell the story.
    Will the quicktime movie open ANYWHERE?
  • Dave Johnson
    December 15, 2009 at 2:14 pm
    As Joe said, the error messages tell the deal … the file is corrupt/damaged … if you’re 110% sure it was originally rendered both properly and completely, it probably became corrupted/damaged while transferring from one drive to another or something similar.
    The first thing I’d do is double and triple check my QuickTime … make sure you have the latest version and that it works fine with any other MOVs. You might also try opening the file on different computers … perhaps with an older version of QuickTime.
    Also as Joe suggests, if you can get the file to open anywhere, run with it … in other words, see if you can get any conversion software to read it and export it to a new file (i.e., Squeeze, ProCoder, Cleaner, MPEG Streamclip, etc.).
    This may seem overstating the obvious, but in my opinion, this can never be overstated … personally, I absolutely never have only one copy of any of my work (including all sources & project files). And, the 3-4 copies I keep are always in different places (i.e., external drives, backups, etc.) … computers are not infallible.
    As an extra safeguard against this kind of thing, its also helpful to always embed project files into your QT movies … if you did that, try importing it as a project instead of as a MOV. Then, if you still have the source media, it’ll probably be much faster to re-render it than trying to get this file to work.
  • Josh Crews
    December 17, 2011 at 8:33 pm
    From my experience, it’s simply a case of Quicktime missing the proper codec to open the clip.
    I got the same error message in AE. I tried to open the problematic .mov files in Quicktime, to see that Quicktime was missing the codec I needed. FYI, you can always do an command i to get info inside of Quicktime to see what the compressor is, then use Google to search and download it.
    Simple fix. Hope that helps.
  • Ruben Contreras
    March 6, 2015 at 12:30 am
    I had this issue and spent all afternoon figuring out what the culprit was.
    I couldn’t preview my videos in quicktime or import them into AE. They played fine in other softwares. All i had to do was download the appropriate codecs from apple and all worked fine afterwards.
    RC
