Activity Forums Adobe After Effects cannot open quicktime movie rendered in AE
  • cannot open quicktime movie rendered in AE
    Posted by Sparky_hd on November 23, 2005 at 10:47 pm
    i rendered a QuickTime movie (no compression) of a project i did in After Effects on a Mac, with QT7pro, i believe. Several months later i’m trying to open in on a PC with QuickTime 7pro and i get the -2048 error saying it’s not a movie. It has a .mov extension. What might be the issue? How does the “uncompressed” quicktime work- is it a special codec or none at all? i no longer have access to a mac or After Effects.
    Adam Lewen replied 14 years, 10 months ago 4 Members · 4 Replies
  • Chris Smith
    November 24, 2005 at 3:53 pm
    I’m just learning this as well. Some codecs just aren’t in the PC quicktime suite it seems. I use “animation” codec to go between PC and Mac. They both like it.
    Chris Smith
    https://www.sugarfilmproduction.com
  • Sparky_hd
    November 24, 2005 at 6:15 pm
    i thought the “animation” codec was the one i used, because there were no compression options. Is that the one?
  • Dreamer
    November 25, 2005 at 6:50 am
    i have same problem what i can to do
  • Adam Lewen
    November 15, 2011 at 12:02 pm
    Hi there.
    I am stuck with in the same situation.
    a quicktime file that came from mac (final cut) and was rendered loseless cannot be open on pc
    Error -2048
    Does anyone know/solved such issue?
    Help needed.
    Adam
