Activity Forums Apple Final Cut Pro Legacy Cannot open Final Cut pro on computer
  • Cannot open Final Cut pro on computer
    Posted by Haley Meagher on August 30, 2010 at 9:23 pm
    When I try to open Final Cut Pro on my laptop it gives me a message that says “• The installed graphics card does not support the OpenGL features recommended by Final Cut Pro.
    • Final Cut Pro recommends that your system have a CPU speed of 1.25 GHz; this system has a CPU speed of only 1000.00 MHz.”. It also says that if I continue it may not work optimally. I press continue and the program just closes. Is my laptop too old to support this program?
    Here are the specs of this laptop:Hardware Overview:
    Model Name: PowerBook G4 15″
    Model Identifier: PowerBook3,5
    Processor Name: PowerPC G4 (3.3)
    Processor Speed: 1 GHz
    Number Of CPUs: 1
    L2 Cache (per CPU): 256 KB
    L3 Cache (per CPU): 1 MB
    Memory: 1 GB
    Bus Speed: 133 MHz
    Boot ROM Version: 4.5.3f2
    Serial Number (system):
    Hardware UUID: 00000000-0000-1000-8000-000A9588561E
    Thank you!
    Tom Bucknall replied 16 years ago 3 Members · 3 Replies
  • John Fishback
    August 30, 2010 at 9:40 pm
    What version FCP?
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.2, Motion 4.0.2, Comp 3.5.2, DVDSP 4.2.2, Color 1.5.2)
  • Haley Meagher
    August 30, 2010 at 10:02 pm
    Hello,
    It is version 6.0 of Final Cut Pro.
  • Tom Bucknall
    August 30, 2010 at 10:43 pm
    “Final Cut Pro recommends that your system have a CPU speed of 1.25 GHz”
    “Processor Name: PowerPC G4 (3.3)
    Processor Speed: 1 GHz”
    There’s your problem right there.
