Activity Forums Adobe After Effects Cannot Move Z Position on Precomp?
  • Cannot Move Z Position on Precomp?
    Posted by Gabriel Bucataru on April 12, 2012 at 2:01 am
    Hi gang!
    Strange behavior. I have a precomp in a main comp where I would like to position it in Z space. If I change the Z value, only the anchor point moves (together with the XYZ – red-blue-green indicator) but not the actual precomp.
    However, changing the X and Y, works just fine.
    The precomp is marked as a 3D layer.
    What am I doing wrong?
    thanks!
    gabi
    Erik Waluska replied 14 years, 4 months ago 2 Members · 1 Reply
  • Erik Waluska
    April 12, 2012 at 2:40 pm
    I would check that your comp view is set to the camera and not one of the orthographic views like front or top. If that’s not it then it could be that your pre-comp has collapse transformations turned on but the layers within the pre-comp are not 3D.
