Activity Forums Apple Final Cut Pro Legacy Cannot move captured footage
  • Cannot move captured footage
    Posted by Css008 on April 6, 2005 at 12:07 am
    I’ve captured footage in FCP 4.5 using a Canopus ADVC-100. When I try to move the captured file from my computer to an external harddrive it gives me the following error midway through the move:
    “The finder cannot complete the operation because some data in “filename” could not be read or written. (Error code -36)”
    I’ve tried converting the file to a MOV, DV, & AVI format but I continuously get the same message. Additionally, I’ve made sure the file is not locked in anyway. Any suggestions on what’s happening here and what I can do to resolve this?
    Kevin Monahan replied 21 years, 5 months ago 2 Members · 7 Replies
  • 7 Replies
  • Kevin Monahan
    April 6, 2005 at 12:10 am
    Is the drive initialized with HFS+?
    Kevin Monahan
    Author – Motion Graphics and Effects in Final Cut Pro
    fcpworld.com
  • Css008
    April 6, 2005 at 12:13 am
    How do I find out? (I’m unsure of what that is ‘HFS+’)
  • Css008
    April 6, 2005 at 12:20 am
    I’m running on OS X 10.3.8 so I’m assuming it’s utilizing the HFS+ filesystem. Anything you would like me to do to confirm this?
    HFS+ is the preferred filesystem on Mac OS X. It supports journaling, quotas, byte-rang locking, Finder information in metadata, multiple encodings, hard and symbolic links aliases, support for hiding file extensions on a per-file basis, etc. HFS+ uses B-Tree heavily for many of its internals
  • Css008
    April 6, 2005 at 12:24 am
    Copied from my Mac System Profile, Hardware Review colum:
    Writable: Yes
    File System: Journaled HFS+
    BSD Name: disk0s5
  • Kevin Monahan
    April 6, 2005 at 1:20 am
    Hmmm…very strange.
    Have you tried using the Media Manager to move the data? You should use the Copy function for this to be safe, then after ensuring that the media copied over, you can blow away the originals.
    Kevin Monahan
    fcpworld.com
  • Css008
    April 6, 2005 at 3:58 am
    Can you give me instructions on how I can find and use the media manager to transfer my files?
  • Kevin Monahan
    April 6, 2005 at 5:21 pm
    Check the Help Menu within FCP. That way you can use the manual with its awesome search capabilities. The manual is really quite good in this respect. Look Up: Media Manager > Copy.
    Kevin Monahan
    fcpworld.com
