Activity › Forums › Blackmagic Design › Cannot Monitor Audio While In Log & Capture
  • Cannot Monitor Audio While In Log & Capture
    Posted by Patrick Mcload on July 18, 2005 at 2:36 pm
    Sorry if this is a simple setting that I’ve overlooked, but I can’t hear the analog audio from my broadcast beta deck while in L&C. I should be able to hear it for scene selection, I/O points. My Decklink Extreme does capture the audio okay and plays it back when on timeline (or any other QT file for that matter).
    I am on a G5 2.7M dual running Tiger, FCP 4.5, connected to a 1.2TB Huge Systems Raid. I capture YUV 10-bit from a broadcast BetaSP (play only) deck. The two XLR inputs are plugged into ch. 1 & 2 out of the deck. The output XLR’s are going into a mixing board and subsequently out through JBL studio speakers/sub-woofer.
    In System Settings, audio out is set to “Decklink audio”. Curiously, in scratch disks, video capture, video render, and audio render are all set to the Raid, but audio capture is grayed out…don’t know if this is the problem, but I doubt it.
    Many thanks for your suggestions.
    Patrick McLoad
    Offshore Films
    Houston
    Patrick Mcload replied 21 years, 2 months ago 1 Member · 0 Replies
  • 0 Replies
