Activity Forums Apple Final Cut Pro Legacy Cannot locate final cut pro data folders
  • Cannot locate final cut pro data folders
    Posted by Bob Davies on October 22, 2011 at 8:11 am
    I have Lion, i am using final cut pro 7. I am trying to load a save file for my keyboard layout but I cannot find my final cut data folders ANYWHERE. I need to be able to put the file there so I can load it from final cut but I can’t find “Final cut data” which contains the “keyboard layouts” folder. Where the heck are they!? This is driving me nuts please help
    Bob Davies replied 14 years, 9 months ago 2 Members · 4 Replies
  • Rafael Amador
    October 22, 2011 at 11:43 am
    All that should be the user Library/preferences/ Final cut pro user data/ Custom Setting.
    I don’t think a different system will make FC save that somewhere else.
    rafael
    http://www.nagavideo.com
  • Bob Davies
    October 22, 2011 at 8:53 pm
    Agreed but when I open try to load the keyboard setting through final cut it opens a window for me to browse for the save file. The default location is opens up to is a file called Keyboard Layout. But I cannot seem to locate this folder when I look using finder. It’s just no where to be found. Even if I do a spotlight search it’s as if the entire folder doesn’t even exist.
    What is the path of folders one would usually follow to get to final cut pro data?
  • Rafael Amador
    October 23, 2011 at 4:38 am
    [Bob Davies] “What is the path of folders one would usually follow to get to final cut pro data?”
    the one i told you; in your user library/Preferences, etc.
    rafael
  • Bob Davies
    November 16, 2011 at 6:09 am
    Thanks! I actually found the problem. Lion blocks you from accessing your library folder. If you go to finder – Go – and then hold alt… it magically appears 🙂
