Activity Forums Blackmagic Design Cannot install Blackmagic codecs on OSX( tiger)
  • Cannot install Blackmagic codecs on OSX( tiger)
    Posted by Daci Gutierrez on June 21, 2006 at 7:26 pm
    Hello, im new to macs and maybe the problem s there
    I have downloaded the blackmagic codecs, installed them as instructed:
    copied “Blackmagic Codec.component” into the /Library/QuickTime directory.
    does not work, neither does the 1st suggested workaround
    * Do a Get Info on the QuickTime folder, located at /Library/QuickTime, and note the Modified Date & Time.
    * in Terminal type in the following commands and then quit from Terminal:
    sudo su [press Return, enter your password and press Return again]
    cd /Library [press Return]
    touch QuickTime [press Return and then quit from Terminal]
    * Do another Get Info on the QuickTime folder located at /Library/QuickTime and ensure that the Modified Date & Time has changed to now.
    The Touch Quickime doesnt seem to change the modified date and time
    , for the second workaround, i cannot find
    the “equivalent location in your Home directory, ie ~/Library/QuickTime.”
    Has somebody run into this problem, wht can I be doing wrong?
    Thank you for help
    Kristian Lam replied 20 years, 2 months ago 2 Members · 1 Reply
  • Kristian Lam
    June 27, 2006 at 8:09 am
    HI,
    What exactly is not working?
    Does it show up in Quicktime Pro’s export options?
    regards
    Kristian Lam
    Blackmagic Design
