Activity › Forums › Avid Media Composer › Cannot install Avid: hangs on:’Installing Digidesign Drivers’
  • Cannot install Avid: hangs on:’Installing Digidesign Drivers’
    Posted by Tom Perry on April 13, 2010 at 3:26 pm
    Hi there,
    I am currently attempting a clean install of my Avid Xpress pro (5.7) software (which I will be upgrading to Media Composer after install), onto my HPXW8400 running WinXP Pro SP@ (32 bit).
    The installation process freezes* when it gets to ‘Installing Digidesign drivers, this will take a few minutes’.
    *(timed at over 30 minutes before I rebooted the pc) .
    I have tried 3 fresh installs and each time the installation freezes when I get to ‘Installing Digidesign drivers’.
    Please, does anyone know how to solve this problem?
    Many thanks for any advice, Tom.
    My system specs: HP XW8400 workstation. OS: Windows XP Professional (32 bit) Service Pack 2.
    System drive: 250GB SATA HDD. Internal Storage drive: 500GB SATA HDD. CPU:Dual Core Intel Xeon 5150@2.66GHz. 3GB Ram. Graphics card: Nvidia Quadro FX 1500. Avid RS232/433 Deck control and firewire 6 pin cables. ADS 64 bit Pyro firewire card. Atto UL4D SCSI card.
    Tom Perry replied 16 years, 5 months ago 2 Members · 8 Replies
  • 8 Replies
  • Matt Mullen
    April 13, 2010 at 3:59 pm
    You probably already have a digidesign driver installed on the machine.
    Try uninstalling it via add/remove programs then installing again.
  • Tom Perry
    April 13, 2010 at 10:37 pm
    Thanks for the reply Matthew,
    I am installing the Avid software as a clean install – I also did a clean install of the Windows XP PRO OS prior to the Avid install – consequently there has been no Avid or Digidesign software installed on the machine – so there is no possibility of any legacy Digidesign drivers remaining on the system to intefere with a fresh install of the Avid software.
    I still can’t work out a way around this – I would be grateful for any other ideas!.
    Kind Regards Tom.
  • Matt Mullen
    April 14, 2010 at 3:31 am
    Have you installed any other devices or drivers?
    Do you have any hardware attached to the machine?
  • Tom Perry
    April 14, 2010 at 10:18 am
    Hi Matthew,
    The only drivers I have installed prior to the Avid installation are the ones required by the Nvidia Quadro FX1500 graphics card.
    There is no hardware attached (e.g. digidesign pro-tools mbox, external video/audio input output hardware etc) that might interfere with the installation.
    I have also carried out the routine XP optimizations stipulated in the Avid optimization for XP pdf document.
    The install will still not proceed past the installation of the digidesign drivers.
  • Tom Perry
    April 14, 2010 at 11:06 am
    Hi Matthew,
    your advice pushed me in hopefully the right direction:
    there are two existing audio drivers installed on the machine which may be producing a conflict with the Digidesign drivers? – these are:
    Realtex High Definition Audio Driver
    High Definiton Audi Driver Package KB8811
    I’ll remove these and then see if the installation goes ahead.
    Many thanks, Tom.
  • Tom Perry
    April 14, 2010 at 7:42 pm
    The problem was Windows Internet Explorer 8 – I removed it and the Avid software installed ok.
    Regards, Tom.
  • Matt Mullen
    April 14, 2010 at 8:11 pm
    Ah, thanks for the update. There’s an array of issues with the IE 8 and Avid.
    I would have never guessed it here though.
  • Tom Perry
    April 14, 2010 at 10:11 pm
    Yep – I did loads of Avid forum searches on this issue and although the problem with the Digidesign drivers came up a lot no one connected the problem with IE8 – until today when someone brought it up at on the Media Composer forum at Avid and IE8 was mentioned.
    Regards, Tom.
