Cannot import 720P/30PN files to Media 100
Gary Stone replied 16 years, 4 months ago 5 Members · 13 Replies
Gary Stone
May 1, 2010 at 4:50 amI too was lured to shoot 720 30PN only now to find that M-100 is not happy with it.
I have footage that I need to edit (and, of course… on a short deadline). The files show up in the import window, but the import button is grayed out. I’m using M-100 13.0.2.
Would importing through another NLE (FCP? Premiere?) be a solution or workaround (to covert to QT)?
John Twigt
May 1, 2010 at 6:12 amWell, you could upgrade to the latest version, it can now handle PN footage. But you could use FCP of course (version 6 or higher) or use Compressor to convert the footage to 720P (in fact doubling the amount of fields and filesize)
hope this helps
John Twigt
Workstation BV, Amsterdam
The Netherlands
http://www.workstation.nl -
Gary Stone
May 1, 2010 at 12:36 pmThanks!
Your prompt post confirms what I was able to conclude after having a few anxiety-ridden hours. (But not knowing that I would find the solution so easy, I had to start the process.)
The upgrade to M100 Suite 1.5.1 is the path of choice. I’m watching the footage import as I’m typing this response. Now I can get some rest.
Thanks again!
G.
