Activity › Forums › VEGAS Pro › cannot hear any audio in Vegas, except for old projects
  • cannot hear any audio in Vegas, except for old projects
    Posted by Michael Hurwicz on November 8, 2005 at 7:28 pm
    Suddenly, I cannot hear any audio in Vegas, except for old projects. I can record and see the
    waveform on the timeline. The track is not muted, nor the clip. I have pushed the V key and can see
    a straight blue line at 0 dB. I can see the green bars bouncing in the Mixer. But I hear nothing.
    This goes for audio created in Vegas or in other applications.
    I can go back to previous Vegas projects and hear their audio fine. I can even bring the new audio
    into previous projects and hear it fine. (So I can work around the problem by importing into an old
    project and saving under a new name.)
    I can also open the new audio files in Sound Forge, iTunes, and several other programs and hear them
    fine.
    Any ideas what could be going on?!
    Mike
    Ted Snow replied 20 years, 10 months ago 3 Members · 4 Replies
  • Gary Kleiner
    November 8, 2005 at 7:48 pm
    Check your audio device setup in preferences.
    Gary
  • Michael Hurwicz
    November 8, 2005 at 8:09 pm
    I think you may be onto something, Gary, as I recently happened to look at the Audio Device setup, noticed it was set to Microsoft Sound Mapper and changed it to ASIO Echo WDM, which I thought would be right for my Layla 24 audio interface. (Even though everything was working fine before I made the change.) I’ll experiment a bit more. Do you know which one is right?
  • Michael Hurwicz
    November 8, 2005 at 9:26 pm
    Changed it back to MS Sound Mapper and it works. Thanks, Gary!
  • Ted Snow
    November 9, 2005 at 7:59 am
    I have both onboard sound and an Echo Mia…when I choose MS sound mapper it uses the onboard sound with my computer speakers…when I choose the Echo driver it uses the Mia which is hooked up to my Mackie 32×8 console.
