Activity Forums Apple Final Cut Pro Cannot get simple Audio only Crossfade to work!!!!!!! OMG
  • Cannot get simple Audio only Crossfade to work!!!!!!! OMG
    Posted by James Bayliss-smith on January 2, 2012 at 6:48 am
    Tearing my hair out here. I love FCP X but it keep messing with me I really want it to work.
    Ok I want to add a audio crossfade. Seemingly very simple, I even got this great plugin
    https://alex4d.wordpress.com/2011/07/11/fcpx-transition-sound-only/
    This is what I am doing
    Detach Audio from two clips
    then select the two audio clips
    then command G to create secondary storyline
    then select the desired edit point
    command T to put a default transition on to audio tracks audio only
    This works fine I have tested it on two clips at the end of the timeline. But within the edit I have just completed it does not work. The transition appears to get added but I cannot hear the crossfade.
    To add to this the bottom half of the green audio track (I know it’s not called a track anymore but that’s what it looks like) is now shaded blue. I can’t for the life of me work this out.
    sending me crazy I use these all the time, any help much appreciated
    John Moffat replied 14 years, 8 months ago 4 Members · 5 Replies
  • James Bayliss-smith
    January 2, 2012 at 7:27 am
    Here’s a screen shot
  • Steve Connor
    January 2, 2012 at 10:49 am
    Have you tried just crossfading the audio with the drag handles?
    “FCPX Agitator”
    January 2, 2012 at 1:15 pm
    yeah that worked but it takes ages. I edit news to tight deadlines, I need a way to quickly do this. The functionality is there but it wasn’t working for me hence the post. What are those mysterious blue shaded sections?
  • T. Payton
    January 2, 2012 at 2:37 pm
    Did you try adding the audio only cross fade to main storyline without detaching the audio? That transition that Alex made wa meant to be used without detaching audio.
    T. Payton
    OneCreative, Albuquerque
  • John Moffat
    January 4, 2012 at 9:39 am
    The shaded blue is what happens when you perform an J-Cut on the audio of a clip in the primary storyline. FCPX let you see the audio waveform for the full duration of the clip but ‘Blues-Out’ where you have have trimmed out the audio in a J-Cut.
    I’m guessing here but since you can’t hear the audio transition and it is “Blued-Out” you might have done something similar to a J-Cut with the audio. Is it possible you have dual mono or stereo audio with one channel silent and have trimmed the channel with audio but not trimmed the client channel?
