Activity › Forums › Maxon Cinema 4D › Cannot get cloth tag to work
  • Cannot get cloth tag to work
    Posted by Ian Watkins on November 28, 2017 at 5:59 pm
    I’m trying to make a simple table cloth. I’m following all the tutorials exactly. I put the cloth tag on the table cloth, and a cloth collider tag on the table, and when I hit play nothing happens. The table cloth doesn’t move.
    To check and make sure things are working, I made a rigid body and collider body tag on the items, and those worked fine; the table cloth dropped on the table and bounced stiff as a board. Not sure what I’m missing. I’m running C4D R18.057 Studio.
    -Ian
    Ian Watkins replied 8 years, 10 months ago 2 Members · 2 Replies
  • Jim Scott
    November 28, 2017 at 8:55 pm
    You need to make the cloth object a polygon object — make it editable. (CMD-C). See the help file for “Cloth Tag.”
    Edit: Whoops. I meant C for the keyboard shortcut
  • Ian Watkins
    November 29, 2017 at 3:39 pm
    Yes that’s exactly the problem. Thank you so much.
