Cannot find clips when importing 120fps footage from Sony A7s2
Hi
I’ve been trying to import a timeline from an XML file created in Adobe Premiere Pro, but keep getting the dreaded “clip could not be found” and “Media offline” issue. I’ve done a lot of google searching and tried so many different things at this stage, but to no avail. I thought that if I describe my specifics below, someone may have tried the same configuration and found a solution that may work for me too.
I had started with a fully edited sequence in Premiere Pro, and was ready to export and import to Davinci to do colour grading when I hit this brick wall. Since then I have reduced my trials to a single clip to try to identify what is causing the problem.
I am using Premiere Pro v12.1.2 (Build 69) on Windows
I am using Davinci Resolve 15
I am shooting on a Sony A7s2
I shot my clip at 119.88fps so that I could achieve a nice slow-motion effect when playing the clips at 25fps.I’ve seen reports that clips recorded at 120fps are not supported in Resolve. Is this correct? If so, I guess this is why I can’t bring a sequence with the clip into resolve directly.
However, I have tried several other things in Premiere Pro such as “interpret footage” to make the clip play at 25fps in my sequence, but the resulting xml export results in the same issue above.
Despite re-interpreting the footage, when I right-click on the clip in my sequence, it still says the clip is 119.88fps.I tried to “render and replace” the re-interpreted footage, but once the clip is rendered, it returns to being played back at normal speed (I assume Adobe has dropped/recoded frames to do this against my wishes/expectations).
Any help would be greatly appreciated as I have spent in the region of 8 hours on this issue alone.
Thanks in advance!
