Activity › Forums › Adobe Encore DVD › Cannot FFD through DVD
  • Cannot FFD through DVD
    Posted by Kevin Morrissey on March 9, 2013 at 3:02 pm
    I have a problem with Encore CS5.1 DVDs. Can someone help please?
    Last year, I could FFD (Fast Forward) through the DVDs I made with Encore CS5.1, but now I can’t. (I haven’t used Encore in a while, so I am not sure when this change occurred.) I thought I was using exactly the same settings, but something must be different. My settings are standard.
    (1) I selected [File], then [Set Disc User Operations]. In the [Disc User Operations] dialog box, I selected [All].
    (2) I selected the timeline, and in the [Properties] panel I made sure that the setting was [Operations: All Permitted]. I also did this with the one menu image.
    Also, I did the following:
    (3) I took out all the audio, and reduced the DVD to 1 menu image, and 1 timeline with a couple of still images. I still can’t FFD through this very simple DVD.
    (4) Tonight, I reinstalled Encore. But it is still not making DVDs that I can FFD through.
    (5) I tried on 2 DVD standalone players, and encountered the same problem on both. However, FFD worked on some computer drives. On a DVD on a Playstation, the image froze but the time count went through FFD.
    Does anyone have any ideas on what the problem is?
    Thanking you in advance.
    Kevin Morrissey
    Kevin Morrissey replied 13 years, 6 months ago 1 Member · 0 Replies
  • 0 Replies
