Activity › Forums › Adobe Premiere Pro › Cannot export to tape from Premier Pro CS6 to my DVW-M2000P Digital Betacam deck
  • Cannot export to tape from Premier Pro CS6 to my DVW-M2000P Digital Betacam deck
    Posted by David Geysar on January 27, 2013 at 9:58 pm
    Hi guys,
    My setup:
    Mac Pro
    OSX 10.7.5
    Premier Pro CS6
    Multibridge Pro
    Sony DVW-M2000P
    my DVW-M2000P Digital Betacam deck is connected to Blackmagic Multibridge Pro, I am having problems exporting to tape in Adobe Premier Pro CS6. I can capture from the deck however I just can’t export to tape. It just can’t sync with the time code.
    I have connected to Multibridge Pro:
    SDI out 1 & 2 (Deck) to SDI in 1 & 2 (Multibridge) and vice versa
    Remote 1 (deck) to RS422 port (Multibridge)
    Can one of you experts advice me on what I am doing wrong, or how I should set up the time code so Premiere Pro and the deck sync.
    Thanks in advance
    David
    David Geysar replied 13 years, 8 months ago 3 Members · 5 Replies
  • Chris Borjis
    January 28, 2013 at 5:37 pm
    I know some folks have had difficulty with that and instead
    use the free black magic capture/output utility to layback to tape.
  • Tom Daigon
    January 28, 2013 at 6:27 pm
    You might check out Walter Biscardi’s site. I think he has had success outputing to tape using BM hardware. Come to think of it , it was to a HD deck.
    Tom Daigon
    PrP / After Effects Editor
    http://www.hdshotsandcuts.com
    https://www.youtube.com/watch?v=DxPrG3WUyz8
    (Best viewed at 1080P and full screen)
    HP Z820 Dual 2687
    64GB ram
    Dulce DQg2 16TB raid
  • David Geysar
    January 28, 2013 at 7:10 pm
    thanks Chris and Tom
    I tried using Blackmagic Media Express, again I am capable of capturing from my deck but when I want to export to tape after 10 seconds I get a message saying “the in point could not be located”
    I wonder if I have the wrong setting on my Digital Betacam deck! Sorry I am a novice and any help is very much appreciated. thanks
  • Chris Borjis
    January 28, 2013 at 9:58 pm
    that sounds familiar like in final cut pro when you don’t indicate
    the in point timecode for where the layback begins.
    Sounds like you might be missing a step.
  • David Geysar
    January 28, 2013 at 11:17 pm
    Hi Chris, you were right, I was missing a BIG something 🙂
    Basically I had to strip the blank tape before exporting to tape.
    So I recorded black video for about a minute then reset the TC on the deck and all problems solved. I was then able to export to my deck.
    thanks
