Activity › Forums › Apple Final Cut Pro Legacy › Cannot export 90 min movie file
  • Cannot export 90 min movie file
    Posted by Joseph Wilkins on January 15, 2009 at 3:59 pm
    I just cut my first indie feature film.. it is 70 minutes long and the client wants a DVD of it.
    When I export it out of final cut at the DV/DVC50 NTSC codec, my mac segments it into nine 2 GB files, and appends -AV1, -AV2… to the end of each file…
    Is this normal?
    Anyway, my problem is that every piece of sofware I try burning it to a DVD crashes.
    I tried compressor… that just hangs when I put the standard 120 min DVD conversion settings on it…
    I tried doing it direct in DVDSP by just bringing in the QT file ( the first of the 9) That just spins for hours then tells me the encoding failed.
    I even tried in iDVD to no luck.
    It takes a day or so to see that it failed, so I am running out of time herre!
    It plays just fine in FCP and QT playerr…
    PLEASE HELP?
    Joseph Wilkins replied 17 years, 8 months ago 2 Members · 4 Replies
  • Steven Gonzales
    January 15, 2009 at 4:09 pm
    Select the drive that you are sending the file to in the finder. Press command-i or control-click and “get info”.
    What is the format of the drive?
  • Joseph Wilkins
    January 15, 2009 at 4:14 pm
    MS DOS FAT 32
  • Steven Gonzales
    January 15, 2009 at 4:25 pm
    Fat32 volumes have a file size limit.
    Try saving to a drive formatted for Macintosh, and you should be okay.
  • Joseph Wilkins
    January 16, 2009 at 4:10 pm
    Ok, so I exported it to a mac drive and the entire file is 17 GB… but I still experience the same problem when taking it to compressor or DVDSP…
    Back to square one!!
    Can you offer any more suggestions?
    thanks!
