Activity Forums Apple OS X cannot delete?????????
  • cannot delete?????????
    Posted by Joe Jennings on June 11, 2010 at 4:55 pm
    Hello,
    Here is the issue… The file is a “HD MPEG-2 18.0Mbps.m2v”. When try to empty the trash i get this prompt….
    The operation can’t be completed because
    the item“test1-HD MPEG-2 18.0Mbps.m2v” is in use.
    Brand new mac pro 2X2.26GHz 8 core with 12GB RAM using newest version of OS X, 10.6.2
    I have closed all applications running on the computer and still will not delete.
    I created this file using compressor after making my original .mov file in Final Cut Pro. I also used apple’s qmaster to create a quick cluster for the computer and had it running while compressing this file.
    Does anybody know what might be going on here?
    thanks
    joe
    Mike Bugera replied 16 years, 3 months ago 4 Members · 11 Replies
  • 11 Replies
  • Mike Bugera
    June 11, 2010 at 5:41 pm
    Not sure the reason but try holding down the option key while emptying the trash. That usually will dump anything.
  • Joe Jennings
    June 11, 2010 at 6:05 pm
    Tried. No Luck. it’s 2.9GB in size,
    would be nice to get rid of it.
    finder can’t locate it either
    weird!
  • Mike Bugera
    June 11, 2010 at 6:20 pm
    Only other thing I can think of is to do a Secure Empty Trash…if you haven’t already.
  • Joe Jennings
    June 11, 2010 at 7:11 pm
    A secure empty trash??????? not sure if i know what you mean
  • Mike Bugera
    June 11, 2010 at 8:47 pm
    Go up to Finder. There should be an option under Empty Trash that says Secure Empty Trash. It takes longer but it’s more thorough.
  • Richert Goyette
    June 13, 2010 at 1:00 pm
    Joe:
    There are a number of reasons that this can happen. Usually, it is easily resolved by techniques such as those described above.
    Recently, I had the problem and finally gave up. Then, I found Trash It at the following URL:
    https://www.nonamescriptware.com/
    It’s free. However, after using it I had no problem making a donation to the creator.
    Rich
  • Zane Barker
    June 13, 2010 at 11:48 pm
    With it saying the file is in use try restarting the computer that should sever any background process from attempting to access the file.
    If that does not work boot into safe mode and empty the trash.
    https://support.apple.com/kb/ht1455
    Hindsight is always 1080p
  • Joe Jennings
    June 14, 2010 at 2:07 pm
    I am trying it now. How long is suppose to take? I have waited 5 minutes now and the empty trash icon appears to be continuing to empty trash but not making any progress. The blue bar is stagnant around 1/3 of the full bar, but still appears to emptying trash.
    joe
  • Joe Jennings
    June 14, 2010 at 2:09 pm
    I will try this.
    thanks
  • Joe Jennings
    June 14, 2010 at 2:14 pm
    Great!! Thanks so much!
    It worked after I restarted the computer.
    joe
