Activity Forums Adobe Premiere Pro Cannot create Large Uncompressed Quick Time file from Premiere
  • Cannot create Large Uncompressed Quick Time file from Premiere
    Posted by Chris Lieber on August 5, 2007 at 12:10 am
    I need to export a file out of Adobe Premiere and for some reason large files will not export as Uncompressed Quick Time files. When I say large, I mean video segments over about 3 minutes or so (3.5 gigs and above). On our last short movie I was able to create the file but for some reason my computer is not allowing me. The file craps out at 99.8% complete and says that the file is not a VALID Video File. Is there a reason for this?? I actually created a set of smaller Uncompressed QT files then put them in a new timeline. I rendered them and then exported again. At the end, I got the same error message. Does anyone know why this is happening and what the work around is?? I need to get the file to a post house to make a Digi Beta tape and only have a week to get this done.
    Many thanks in advance.
    Brian De herrera-schnering replied 19 years, 1 month ago 6 Members · 8 Replies
  • 8 Replies
  • Chris Lieber
    August 5, 2007 at 12:16 am
    the error message is #
    -2048
  • Deleted User
    August 5, 2007 at 2:36 am
    Hello,
    This sounds like you are exporting the referance file for “Quicktime”, not an actual video file. But the referance file.
    Please re-check your Quicktime files and make sure it is not ouputting the Quicktime as a “reference file”, I have seen this error before and it is the exact same issue you are experiencing.
    Leo Baker
    Post Production
    Sync Films
    United Kingdom
    http://www.syncfilms.com
  • Chris Lieber
    August 5, 2007 at 4:53 am
    I am going into File/Export Movie => Settings/General => File Type = Quick Time
    Embedding Options = Project
    Video => Compressor = None / Color Depth = Millions of Colors
    Key Frame and Rendering => Rendering Options = No Fields (Progressive Scan)
    Optimize Stills = checked
    Where is the “reference” file at?
  • Chris Lieber
    August 5, 2007 at 9:37 am
    QT 7 is not compatible with Adobe. that is why everyone is having problems. I uninstalled 7 and reinstalled 6.5. now everything works….
    I think I am going to have to spread the gospal about this revelation. QT 7 is the devil that’s for sure….
    thanks for the reponse though
  • Steven L. gotz
    August 5, 2007 at 7:29 pm
    I believe that 7.1 is fine but the current 7.2 is fouling things up.
    Steven
    https://www.stevengotz.com
  • Blast1
    August 7, 2007 at 7:19 pm
    Its on and off, 7 didn’t work, 7.1 did, 7.2x problems
  • Bimdas
    August 9, 2007 at 5:50 am
    Seems everytime a new quicktime is released it only affects adobe editing products. Something seems a bit suss there.
  • Brian De herrera-schnering
    August 10, 2007 at 3:05 pm
    Sounds like you are using a FAT32 formatted disk which has a file size limit of just under 4G. Try a NTFS formatted disk or exporting to a compressed fomat.
    Brian
