Activity Forums Apple Final Cut Pro Legacy Cannot copy media file
  • Cannot copy media file
    Posted by Neobe Velis on May 14, 2006 at 8:50 pm
    I’m using FCP 5 and a Lacie 500MB Big Disk Extreme. I have a recurring problem (this has happened on multuple projects with the same file name erroring out) I am unable to copy a media file titled 1-v or 1-a. All of the other media files seem to work fine but this one errors out if I try to drag copy it or if I use Media Manager. It gets all the way to the end of copying a 12GB file and then errors out in the last 5 seconds.
    Does anyone have any suggested on how I can move this file?
    Neobe
    Neobe Velis replied 20 years, 4 months ago 2 Members · 2 Replies
  • David Fortin
    May 15, 2006 at 12:15 pm
    Where are you trying to move it to?
    The HD must be formated for MAC Extended or similar. If it is an EXT drive that was formated for Windows/MAC then there is a 5GB limit.
    I had this problem copying files until I realized about the Windows limit.
    This may not me your problem, but I thought I would post just in case it was.
    Good Luck,
    David
    Dual 2.5 G5 {OS 10.4.5}
    4.5 GB RAM
    FCP 5.0.4
    NVIDIA GeForce 6800 Ultra DDL
    DeckLink SP
    ATTO ExpressPCI UL4S
    Medea Video Raid RT320
    Sony UVW-1800
    Pansonic AG-DV2500
    Media Cleaner Pro 6
    Squeeze 4.2 (PC)
    ViewSonic 19″ LCD
    Optiquest 21″ CRT
    Bella EZ Keyboard
  • Neobe Velis
    May 16, 2006 at 3:10 am
    Thanks David. I checked and they are formatted MacOS Extended. I’m moving from my drive to a client’s drive. I guess I’ll just pull that video in again because I just can’t figure out how to copy it.
    Neobe
