Activity Forums Apple Final Cut Pro Legacy Cannot copy “file name” : The file or directory is corrupted or unreadable
  • Cannot copy “file name” : The file or directory is corrupted or unreadable
    Posted by Joshua Booth on September 21, 2005 at 6:12 pm
    Here is my problem. I export my video from FCP as an AVI. I then need to transfer it to a PC so I can encode it as a variable bit rate WMV file. If the AVI is over a gig I will burn it to a DVD. Then I put the DVD in the PC. Open the disc and When I attempt to drag or copy the file to the PC I get this error, “Cannot copy “file name” : The file or directory is corrupted or unreadable.”
    This process worked fine, until about two months ago. Also, It gives me the error on any PC I attempt it on, so I don’t think it is a PC problem.
    If anyone has any ideas as to what the problem may be or how to fix it, I would really appreciate it. Thanks.
    Joshua Booth
    Editor
    iQ Digital
    121 S. Main St
    Akron, OH 44308
    330-374-6799 ext. 247
    https://www.iq-digital.com
    Josh.Booth@iq-digital.com
    Kevin Monahan replied 21 years ago 2 Members · 1 Reply
