Activity Forums Adobe After Effects Cannot Change Text color?
  • Cannot Change Text color?
    Posted by Jaz Burley on September 2, 2010 at 1:00 pm
    I am using a template from a site in which you can alter text, scale it, change font etc. But I cannot change the color via Hue/Saturation, I want it to turn a metallic kind of color but it will not change, whereas every other effect and footage will.
    Any Ideas?
    Jaz
    John Omar replied 13 years, 2 months ago 6 Members · 10 Replies
  • 10 Replies
  • David Johnson
    September 2, 2010 at 3:08 pm
    Why would you change text color via Hue/Saturation anyway? Why not just change the color of the text?
    https://help.adobe.com/en_US/aftereffects/cs/using/WS3878526689cb91655866c1103906c6dea-7cf6a.html
  • Erik Waluska
    September 2, 2010 at 5:45 pm
    Select the text layer and hit “UU” to reveal all altered properties, effects, etc. It could have a fill effect or something that is below the hue/saturation in the effects stack.
  • Jaz Burley
    September 2, 2010 at 8:59 pm
    Interesting but Can’t seem to do anything to it.
    Look what happens when I change it’s color, here’s a screen shot.
  • Joey Burnham
    September 2, 2010 at 9:22 pm
    It looks like it has a color fill animator on. If you turn the twirly next to “text” you should find it. That’s why only the last letter is turning red. If you adjust the offset properties of the text animator it should fix it.
    Joey
  • Jaz Burley
    September 3, 2010 at 11:45 am
    Bad argument couldn’t
    find layer named ‘Master
    Text only change here’
    Expression disabled
    Ummmmmm?
  • David Johnson
    September 3, 2010 at 1:31 pm
    If I understand your last post correctly, it sounds like that’s an error message that you’re getting … can’t tell because the color picker is covering the area where an expression may be shown, but especially since you mentioned this is a template you bought, it sounds like you have an expression that got screwed up somehow … did you change the name of a layer it refers to or something? If so, change it back.
  • Jaz Burley
    September 3, 2010 at 1:55 pm
    Ok, somehow I’ve managed to change text color etc on it, so that’s good.
    But When i add a color curve effect, the whole background and composition is effected?
    Hmmmmm?
  • Jaz Burley
    September 3, 2010 at 2:48 pm
    Ok that’s not even a problem anymore, I’m back to sqaure 1, accept I’ve made my text gray now.. can’t add any effects again etc
  • Jack Kalish
    April 3, 2013 at 4:54 pm
    That link is broken…
    https://www.jackkalish.com
  • John Omar
    July 11, 2013 at 6:17 am
    Apply “Tint” from effects and presets
    Then from Map choose your color as tint and adjust ad desired
