Activity › Forums › Adobe After Effects › Cannot change anti-aliasing mode for comp?
Posted by Adam O’hern on June 19, 2015 at 3:49 pmHi all,
According to the docs, there should be an advanced Comp setting for AA filter, offering ‘none’, ‘box’, ‘tent’, and ‘cubic’ modes. I’m not seeing this setting anywhere in the Comp settings. Can anybody point me to the right place?
AdamWalter Soyka replied 11 years, 2 months ago 3 Members · 4 Replies -
Michael Szalapski
June 19, 2015 at 4:53 pmAre you in a composition that’s using the ray-traced renderer? That’s just for ray-tracing things. (icky!)
– The Great Szalam
(The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)No trees were harmed in the creation of this message, but several thousand electrons were mildly inconvenienced.
Adam O’hern
June 19, 2015 at 4:57 pmAh, I see. So I guess I can’t control the AA filter that’s used on images more generally? I’m doing a UI mockup with tiny icons, and the AE AA filter is making them blurrier than they need to be. I’d like to use the raw pixel data if possible.
Michael Szalapski
June 19, 2015 at 5:07 pmMake sure you’re placing your items on full pixel integers. If it’s a two-pixel-wide line, you’re splitting it between three pixels unless you have it at an x.5 position. Does that make sense?
And/or choose draft mode for your layers (and output).
– The Great Szalam
Walter Soyka
June 20, 2015 at 4:00 amSee this post on subpixel resampling for more:
https://forums.creativecow.net/readpost/2/1063290
Walter Soyka
@keenlive | RenderBreak [blog] | Profile [LinkedIn]
