Activity Forums AJA Video Systems Cannot capture with IO la
  • Cannot capture with IO la
    Posted by Max1nguyen on September 9, 2005 at 1:16 am
    brand new g5 dual 2.7 tiger. Updated OS from software updater, final cut pro to 5.02
    Have a kona 2 hd installed
    Using IO LA for analog
    Trying to caputre from sony betacam analog through IO la.
    Downloaded newest firmware, loaded it and power cycled
    updated firmware from the new control panel
    Made sure I was using IO LA installs.
    checked cables, deleted preferences…
    CANNOT see any video input in capture window. Checked cables tried all inputs. S-video, composite, component… Nothing. Just color bars that say preview disabled.
    when just pressing capure now, message says deck not in vtr mode.
    checked to make sure switch on deck was flipped to proper outputs… All correct.
    Check the control panel… It says no video input
    Led on IO la shows there is input and changes to the proper light when I switch from s-video to component etc…
    I have to solve this immediately.
    Can anyone please help?
    Sorry I was not able to peruse forums if there is an question similar… There is no time…
    Lee Berger replied 20 years, 11 months ago 5 Members · 8 Replies
  • 8 Replies
  • Bob Zelin
    September 9, 2005 at 2:46 am
    Have you simply gone to EASY SETUPS and selected a setup, like Betacam 8 bit uncompressed? If it’s on DV, you ain’t gonna get anything ! If you still don’t get anything after you do an easy setup, go into audio/video settings, click on Capture Presets, scroll down to whatever is checked, double click on this, and see what is actually selected in this window for the video input.
    bob Zelin
  • Max1nguyen
    September 9, 2005 at 2:56 am
    I have an IO at home, but man, this stuff just does not work. Sad to say, things worked fine for me when blackmagic used to write the drivers… Yes, this was Wayyy back then when the first kona hd was out… I had the IO then as well.
  • Max1nguyen
    September 9, 2005 at 2:59 am
    yes I checked the easy setups. First thing i did… But the second part of your suggestion, I did not check… I will look at it when I get back in the morning. Million dollar bet that is going to look right. But who knows… Let you know about it.
  • Max1nguyen
    September 9, 2005 at 3:01 am
    wrote the newbie part before your post came up. Thanks for the reply, Bob. Just thought that no one would pay my post any mind since it seems so rudimentary.
  • Jeremy Garchow
    September 9, 2005 at 5:14 am
    If you’re sure the config is correct, call aja and they will promptly switch out for a new one. If your io at home works, why don’t you bring that in to use in the meantime?
    G5 Dual 2Ghz <> 4GB RAM <> FCP 4.5 <> Kona 2
    ATTO 42XS <> Huge Systems 1.25 TB 4105 Fibre
  • Dave Jenkins
    September 9, 2005 at 11:56 am
    We had this problem, trashed the prefs in FCP and all was fine. I have two AJA LA and one IO and have very little trouble with them.
    Dajen Productions
    Santa Barbara, CA
    G5 Dual 2 Gig – AJA IO & LA
    Huge 1.2 Raid
    FCP 5-OS X 10.4.1-QT 7
  • Bob Zelin
    September 9, 2005 at 10:55 pm
    Hello Max1 –
    your post is NOT a newbie post. I went into an AJA I/O today, with the updated firmware, and could NOT get any video into the system, until I
    went to the Pro I/O control panel, and switched it BACK to ANALOG and component, instead of SDI and embedded audio. I had set this a few days ago, and the system was powered down, and when it came back up, it defaulted to SDI embedded, instead of Analog.
    SO, I quickly learned how to use the PRESETS tab, which is the first tab in the Pro I/O control panel.
    So, this is NOT a newbie question. but the real question becomes – is this a feature, or a bug??????
    bob Zelin
  • Lee Berger
    September 9, 2005 at 11:13 pm
    I’ve had this problem ever since the control panel was fully implemented. I set one or more presets and the next time I boot up they’re gone. The IO defaults to SDI input. I sent a note to AJA, no response.
    Lee
