Activity Forums Blackmagic Design Cannot capture analog XLR audio input using Multibridge
  • Cannot capture analog XLR audio input using Multibridge
    Posted by Giacino on August 21, 2006 at 8:33 pm
    I am trying to capture external audio using the analog XLR audio inputs on the Multibridge extreme, but can’t seem to get any signal in.
    I’ve set up both the OS X audio system preferences and the DeckLink pref, to use analog audio (from multibridge), but no signal comes in.
    I need to use the VoiceOver feature in FinalCutPro to lay over audio over the video, but so far I can’t seem to get any analog audio from the MultiBridge.
    I’ve read that the Multibrridge Extreme requires a token video source to be supplied to capture audio channels accurately. If so, it is a currently limitation, is it by design or is it a bug (with a potential firmware fix).
    Any solution or workaround? Or do I simply need to feed a video signal into the multibridge which capturing the audio?
    Please let me know,
    Guillaume
    Dovydas Vilkelis replied 17 years, 11 months ago 3 Members · 3 Replies
  • Andrew Mcleod
    August 24, 2006 at 5:44 am
    Hi
    To capture audio channels you need to supply a token video source for the audio to be embedded to. The token source should be the format you are working with. Blackvideo or sync as input via the SDI would work OK.
    email support@blackmagic-design.com if you have any more questions.
  • Andrew Mcleod
    August 25, 2006 at 12:38 am
    Sorry not “Sync” Stable Black video.
    thank you.
  • Dovydas Vilkelis
    October 1, 2008 at 2:48 pm
    I have the same problem, and have no video source. How could I put black video? Could you explain this step by step?
