Activity Forums Blackmagic Design Cannot Capture Analog With Intensity Pro
  • Cannot Capture Analog With Intensity Pro
    Posted by Jeremy Gadd on May 16, 2010 at 8:24 am
    Having finally got IP to work I now find that I am having problems capturing anything analog. I am using the break out cable and have got the correct leads and inputs. What happens is that when I try to capture (using either BM’s media express or Adobe Premiere 4.2.1) it captures a few frames then goes black. Captures a few more and then goes black again. In real time it just looks like a flicker.
    I have even tried using different leads to check if it is a cabling problem.
    Windows 7 64 bit
    Intel dual core 2.8ghz
    Asus P5QPL-VM
    4gb ram
    Intel G41 integrated GPU
    http://www.asounddesign.eu – UK Based Video Editing, Multimedia and Web Designer
    Kristian Lam replied 16 years, 4 months ago 2 Members · 1 Reply
  • Kristian Lam
    May 17, 2010 at 1:35 pm
    What kind of analog? Is it composite or component? What is the source of the video?
    regards
    Kristian Lam
    Blackmagic Design
