Activity › Forums › Apple Final Cut Pro Legacy › cannot batch capture??
Posted by Toby Levins on August 4, 2008 at 11:23 amHello all,
I have a new HV30 and have just logged my first tape, but when I select batch capture, nothing happens at all? Am I missing something?? The tape is actaully an old dv, but the capture settings are all good (I think) as FCP can see and log the footage…any hlpe much appreciatedTom Wolsky replied 18 years, 1 month ago 3 Members · 8 Replies -
Tom Wolsky
August 4, 2008 at 11:30 amPlease give your full system specifications, what computer, what drives, what camera or deck, how everything’s connected, what settings are on the media, what settings you’re using in Final Cut, and finally what version of the software, of the OS, and of QuickTime are you using?
All the best,
Tom
Class on Demand DVDs “Complete Training for FCP6,” “Basic Training for FCS2” and “Final Cut Express Made Easy”
Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 4 Editing Workshop” -
Toby Levins
August 4, 2008 at 11:46 amI have FCP studio 2, running on a Macbook 2.16 running leopard. Using DV firewire 48kHz. And I have Quicktime 7.5
Tom Wolsky
August 4, 2008 at 11:50 amThanks for the detail. Any other drives or devices attached? Does the application recognize the camera at launch? Are you using FireWire Basic? You should be with a Canon camera.
All the best,
Tom
Toby Levins
August 4, 2008 at 11:59 amhmm, hv30 is plugged direct into a external HD, which is tneh firewire into the computer. Have just tried firewire basic, and nothing.
The computer sees the camera on startup and logging works perfectly?/ thanks for the prompt reply -
Toby Levins
August 4, 2008 at 12:05 pmand if it helps, I can’t do a normal clip capture either, just nothing happens ?
Dan Dennis
August 4, 2008 at 12:17 pmDo you have more than one firewire input into the computer? It may be that you need separate firewire buses in order to capture. It sees the camera as the second device in the stream, but it’s not capturing because the drive is the first device.
If you have the budget (and if the laptop has a PCMCIA or ExpressPC slot) consider getting a firewire card. They’re not that expensive, and it may solve your problem.
“Like the fella once said, ain’t that a kick in the head?” – Dean Martin
Toby Levins
August 4, 2008 at 12:28 pmyou were bang on (or atleast I think). I plugged the cam direct into the firewire port, and it worked just fine. I know I have gone camera – external-computer before, but maybe that was on a machine this a seperate firewire port ?? unfortunately the macbook only has one firewire and no PCMI. SO I guess I will have to capture direct to the lappy, then most it across to the external. I should get any broken links if I copy the whole folder across ??
thanks for your help 🙂 -
Tom Wolsky
August 4, 2008 at 2:31 pmCanon cameras do not work well when there is another device on the same bus.
All the best,
Tom
