Activity › Forums › Apple Final Cut Pro Legacy › Cannot add BPAV folders into XDCAM Transfer for conversion to FCP7.
  • Cannot add BPAV folders into XDCAM Transfer for conversion to FCP7.
    Posted by Cullen Smithson on November 5, 2013 at 7:15 pm
    I’m using 2.5.1 XDCAM Transfer but when I’m trying to “Add Source” folders the BPAV folders (on an external HD) are greyed out when trying to add them.
    Eventually I want to import this footage to FCP 7.
    Running OS X 10.6.8
    Any suggestions why I’m not able to add these folders?
    Cullen Smithson replied 12 years, 10 months ago 2 Members · 2 Replies
  • Rafael Amador
    November 5, 2013 at 10:34 pm
    Is the BPAV folder inside another folder?
    If not, open a new folder, name it and put the BPAV folder inside.
    In XDCAM Transfer you have to add the new folder.
    You have to do the same to each BPAV folder.
    rafael
  • Cullen Smithson
    November 5, 2013 at 10:43 pm
    I needed to update the XDCAM Transfer tool. I used this…2.13 is available under ‘legacy applications’ at https://www.sony.com/xdcam-downloads
