Cannot achieve smooth playback on my editing platform
I have a new editing platform that should be very good, but I cannot get it to playback by projects without jerkiness or at decent video quality. If I encode and playback elsewhere (ex: on a WDTV Live or even on YouTube or Vimeo) the quality and smoothness is just fine. But on my editing PC it is not.
First, here is my rig:
Adobe Premiere CS4 latest versions
Dell Studio XPS
Windows 7
Intel Core i7 920 @ 2.67GHz
12.0GB RAM
OS drive is 1TB Western Digital Caviar Black
Footage drive is a 3-drive RAID 0 array of Western Digital Caviar Black 2TB 7200 RPM 2.0TB drives (6TB total)Here are the symptoms:
I render everything in the timeline and then play it back. It is “jerky”. For example, I have some Adobe After Effects animations of photos moving slowly across the screen and they are not smooth, but rather move in a slightly stepwise fashion.
I then encode to a final file (say a H.264 output destined for Vimeo) and it still seems jerky.
HOWEVER, if I play that same file back off the WDTV using a much slower hard drive (a MyBook Elite 1.5TB portable drive connected with USB 2.0) it is perfect — pristine video quality and rock solid smooth. No jerkiness at all.
Here is the video on Vimeo if that helps:
Any ideas on what the problem might be or how I might be able to diagnose it?
Neil Myers
Connect Public Relations
CS4 Master Suite, 3DSSome contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
