Activity Forums Adobe After Effects can´t import aec in after effects cs3
  • can´t import aec in after effects cs3
    Posted by Toke Møller on June 12, 2008 at 3:45 pm
    Help!
    I know there are threats about this topic, but none which helps me
    When I try to open the aec file in AE cs3, created i cinema, nothing happens!
    I´ve downloaded the newest plug in on MAXON site
    I know the aec file is ok, since I can open it on other computers
    I have the latest upgrade for cs3
    I’m working on OS Leopard …
    Hope somebody knows whats going on …
    ps It won´t even work on AE7
    Francois Moron replied 14 years, 10 months ago 13 Members · 16 Replies
  • 16 Replies
  • Bill Kelly
    June 12, 2008 at 10:32 pm
    Inside the MAXON folder on your HD, navigate to the Exchange Plugins folder. Inside there is an After Effects folder. Inside the After Effects folder, there are folders that will say mac 5.0, pc 5.0, etc.
    Choose the one most appropriate to your OS and AE version. I think 6.5 is the highest so if you’re running 6.5 or above choose that one. Inside that folder is a plugin (you may have to unzip it). Copy that plugin to your After Effects plugin folder. Now you should be able to import the .aec files directly into AE.
  • Toke Møller
    June 13, 2008 at 7:14 am
    Thanks for the response!
    But that is not the problem, I have copied the exchange plugin in to the AE plugin folder …in fact I have downloaded MAXON newest version since i´m running CS3 …
  • Joel Bailey
    June 19, 2008 at 1:14 am
    Bill,
    I was having the same problem and your solution solved it! Many thanks.
    -Joel
  • Eric Woods
    June 27, 2008 at 3:11 am
    Have you found a solution to this yet? I am still struggling.
  • Josh Crews
    February 5, 2009 at 4:48 pm
    Thanks Bill. I followed Bill Kelly’s steps (2nd thread in this post) and I’m now able to import C4D project into AE.
    I’m using AE CS4, but the CS3 plugin works fine.
  • Mycal Barrowclough
    March 30, 2009 at 12:26 am
    Arrrgh. Ok. I’ve followed the instructions and copied the “cinema4DAE” into my AE plugins folder. Infact, I wasn’t sure which subfolder to put it in so i put it in EACH subfolder plus the plug-ins root. I’ve rebooted, restarted, and it still doesn’t seem to want to accept my AEC file. Any help?
    Mycal Barrowclough,
    Fat Monkey Media, Owner
  • Juan Olivares
    April 8, 2009 at 2:49 am
    try to put the C4D plugin in the following Directory
    Mac OS/Application Support/Adobe/Common/Plug-ins/CS3
    For some reason my plugins are working in that directory and not in the standard directory…
    hope it helps!
  • Justin Mays
    August 30, 2009 at 2:40 am
    tried all of the above and still nothing – AE even says on the top right box its loading the file but still nothing. I’ve tried reinstalling C4D and AE CS3 & CS4 and still nothing. So frustrating!!!
  • Mark Lee
    September 30, 2009 at 5:36 pm
    Hi
    i had problems too. I ended up sticking it in the After Effects Presets folder NOT plugins and that worked for me….
    hope that helps.
  • Ariel Cabrera
    February 26, 2010 at 1:52 pm
    thank you bill kelly for te post!!! you save my day!
